what front wheels will work on the daytona 650...
will the sprint rs or t595 wheel work?
thanks,
Chris
Bikebandit.com has listings of oem part numbers. you could go there and do a search to see if part #'s match for other triumph models.
thanks...
so i need a tt600, D600, or d650 front wheel...
thanks,
Chris
I'm not sure if a TT600 or S4 wheel would work, as they too have speedo sensors on the wheel while the D600/D650 does not.
I expect the wheel would work, since the sensor is probably replaced by a spacer. You might have to get the little metal ears out of the hub to get the spacer to work properly. I don't know for sure, but it would be worthwhile information for the forum if anybody knows.
