1 - 9 of 9 Posts
I'm getting some shaking from my thrux front wheel at about 45mph (indicated). Everything is tight and looks right, air pressure is right. Never noticed this before but I haven't been on the bike in a while. Is this common?
As my front tire wore, this became worse. To the point if I ran hands off it would continue to degrade.
New tire and back to the old smooth ride. I ran the stock tires about 1500 miles too long. For me, the change came at 11,000 miles.
It is not normal or common. I also ran without a front fender for a while, and thought not having the fender support may have allowed some flex in the forks. In my case, it was the worn tire.
[ This message was edited by: whoa on 2007-03-11 11:56 ]
Tire pressure (reckon you checked that) and steering stem bearings being loose can cause this. Just tossing this out there since I have seen this before.
Good luck
Did you ever solve the problem?
Are you still running stock tires ? Those Lasertecs cup easily and IMO pretty crappy . If a rebalance doesn't fix it just buy a new tire .
Get Pirellis . I have the Avon AM26 and developed a high speed " Wobble " in the front with the universal front . Wouldn't recommend them if you ride at high speeds a lot(95mph+). Other than that a decent tire.
1 - 9 of 9 Posts
