1 - 7 of 7 Posts
I am re fitting my front fender and have no torque settings to work with. I have placed rubber grommets between the support braces and the fender and done everything tight. I have not leant on the wrench or anything.
Can you guys recommend any torque settings.
I wouldn't normally bother, but I want to avoid something coming loose and jamming in the front wheel
The "stay" bolts with the nylon washers for the mudguard to the braces is 9 Nm. The braces to the folks is 24 Nm.
That is for Bonne, T100 & Thrux. America and Speedmaster are different.
But he's also up against a rubber grommet, would a torque setting even apply?
Good point. But I took the values straight out of the Triumph manual. Even if there is a washer, bushing or sleeve torque values apply. Torque is torque. Compression is compression. Engineers have established a torque value for the object. So that's what I gave him.
Me personally, I am a by the tech manaul kind of guy but for those items I would just tighten them up to a nice feeling of tightness. Elbow torque wrench value. :) But he asked so I looked it up.
The actual grommet is nylon not rubber but I figured that is what he meant. Now that I re-read his post it sounds like he replaced the nylon with rubber - That does throw a factor in there that is not engineered. Is the rubber the same consistency of the OEM nylon? Is the rubber a thickness variance of the OEM nylon.....? Was the rubber cold causing a density change? Lot's of factors to take into account. o_O:rolleyes:
Snug up and go.
Thanks for the invaluable help everyone. I searched everywhere.
I will replace the runner with the plastic grommets and torque up to spec. I love the elbow torque wrench, but I doubt my work too much and quadruple check everything. Damn my OCD 😏
1 - 7 of 7 Posts
