1 - 2 of 2 Posts
So i bought my t bird last fall, and ever since then the front fender has lots of play, up and down and side to side. It looks to be riveted on either side of the tire. is this normal? do you all have pictures of what the mounts are supposed to look like? any help would be greatly appreciated...
The mudguards are all riveted but there should be no play. Have you checked where they mount to the forks, if the bolts are slightly loose you can get quite a bit of play.
1 - 2 of 2 Posts
