1 - 7 of 7 Posts
I was wondering what folks have used for a front end lift for the Rally Pro.
I have both front and rear Vortex Paddock stands. Rear works fine. But the front, with the the 21” wheel and 230mm of travel, the front stand isn’t tall enough to fit the pin. Trying to avoid building a set of lift blocks (2X8’s and 2X4’s etc…) but if that’s the only way, I will go that route. I have an “A” frame that I can hang the front from, but it takes up too much room.
Any thoughts or suggestions?
RD
Why do you need a front lift? Just put it on the center stand and place a car jack under the sump gard to keep it from falling upwords.
This is how I did it when I removed both wheels to change the tires.
What he said.
Also, I do one extra security by tying a bungee cord from the foot of the center stand to the foot peg so the center stand does not accidently fold up when wrestling with the front wheel.
I would say yes.
First you mount the front wheel as you can rack the bike backwards (you simply lift the bike from the forks). You have freedom of movement. It's not a struggle as the bike is almost balanced. After that you remove the car jack and the bike will tend to sit on the front wheel.
You move to the rear side.
I placed Conti TKC 80 which have way thicker thread than the standard tire.
I don't see why you would have problems with other type of wheels/tires either.
2020 Tiger 900 GT Pro
I was referring to installing taller wheels on the paddock stands
I use both methods. The floor jack works fine for something quick but the paddock stand provides better stability for longer jobs.
Discussion Starter · #7 ·
Agree…
After spending years as an owner operator of a motorcycle shop, the “Just put a floor jack under it” method is well... just asking for trouble. The number of bikes fallen over that way is just too numerous to count. The mechanic involved was always “I was only planning on leaving it that way for a short time”… right :rolleyes:
It looks like I gotta go up like 4” and never thought of the larger wheel… don’t know if I can find one but great option! Thanks!
RD
1 - 7 of 7 Posts
