1 - 20 of 170 Posts
Cracked Frame with Center Stand
So, I go out to wash the bike & put it up on the center stand & notice it's not sitting right. It's sitting on the right pad of the center stand and the part that you put your foot on to get it up on the stand. The left pad (near me) isn't hitting the ground & the bikes leaning to the right a little bit. Hmmm. do some looking around & find the frame is cracked on both the left & right sides allowing the center stand to go too far forward. Called the dealer & the service guy said "We'll pick it up, don't ride it." So, it goes into the shop Friday. Could be there a couple month's since they'll probably have to replace the frame. If you have a center stand, you might want to check it out. Could be a recall coming.
Looking back through the OP's posts, it's a new Street Twin fitted with accessory stand part number A9778019.
Is it the tabs, labelled 3, that are broken?:
More drawings in the fitting instructions here, see if you can point out where the break is, it'll help others to check their frames or even better, a photo:
http://www.triumphinstructions.com/ProdDocs/A9778019-EN.pdf
Mods: Perhaps it might be worth changing the title to include "broken frame" in the title, it would attract more views to what could be a serious safety issue.
It does look like the tabs pointed out in the drawing above labeled 3. I'm at work right now & computer challenged but I'll try to post pics when I get home.
Must have been poorly welded to the frame. I use those tabs to lift the rear wheel with a scissor jack and they seem rock solid to me.
gary15068,
Looks like the center stand bracket welds broke at their beads. This is a serious problem that will get Triumph's attention. I'll bet that you'll be getting a new replacement ST since this one will likely be undergoing extensive failure analysis.
The center stand brackets on my T120 are designed in much the same way. I inspected them and found no problems.
Glad you were not hurt. The dealer was right to advise that the bike not be ridden.
Hope you'll keep us posted!
That part of a bikes frame takes some serious twisting load once the weight of the whole bike is on the stand. No wonder triumph withdrew sale of their centre stand kits.
The brackets design and quality/depth of those welds would be OK on 50cc moped. Appaling on plus 200kg bike.
And this perhaps explains the bikes shortage of supply. What do you do with the runs of production in stock and going through the distrbution network when you discover this. Your only option is to stop production and distrbution. Then test and inspect every bike to see how wide spread the fault is.
My guess is you can't order a new bike with a stand. And those that have them will be recalled and removed at the first service. Fact they just launched a step up in production suggests they think the problem is now corrected on the welding line or perhaps a revision in design?
The danger here is that bikes fall over as the brackets will pull off the frame. Probably the more heavily loaded with luggage at first. Then more as the welds fatigue with use. If it falls the riders way then not so bad as the foot bracket will slow it down. If the other side breaks off the bike will fall away from you and out of your control. If that's onto a passer by, into a line off passing traffic or into a car or bike parked along side then you will have an insurance claim against you.
What's important to watch is how Triumph deal with current bikes. All are suspect for now. Looking at the design I doubt any extra strength can be bolted on. Next option is to improve the welds and perhaps a clever extra plate or two but the stripping out of anything sensitive to the heat of welding could be a major job fraught with yet more problems. And then the problem of restoring the paint finish if its original doesn't burn off too badly from the heat.
gary15068,
Thanks for the pics! Forgot to ask, how long have you had the bike (mileage) and how often did you use the center stand. I'm curious if this will be an up and coming issue for everyone. I have an ST and installed the oem center stand. I do not have the issue, so far.
You've definitely got me worried. I use the centre stand all the time and there does seem to be a design weakness at the root of this. Replacing or modifying frames could be a nightmare. Thanks for the information and pictures.
Some dealers list stands. Others not. And they might blame the problem on a DIY fit so all beware.
From a snoop round my dealers I think the other frames are slightly different so with luck missed this dodgy welder/operative. Triumph might know the frame numbers by now which need fetching in. That welding station will have performed more than just the stand welds. They can play the numbers down because not all will have stands. That said does anyone know if the crate stand uses the same lugs. My frame shows signs of something having been fitted there.
My Warranty says report any suspected fault within two weeks or could be void.
The practice of heaving the bike off the stand by sitting on it and heaving your arse forwards will put a lot more strain on the welds...I've seen folk do that even with a passenger.
Yes that's not what a stand is intended for.
In my experience a weak old stand, its pivot or frame brackets break as the bike is put onto the stand when its loaded with panniers and a top box. This just as the whole bikes weight goes over centre and stops abruptly as the stand stops strike against the frame brackets. The mechanical advantage is about 10:1. Length of stand versus length of welds from centre of pivot. Assuming half the static load once the bike is on the stand is in the stops. The rest on the pivot. A 200kg bike easily puts 1,000kg load onto its stops if you slam it onto the stand (dynamic). Means each bracket gets about half a ton trying to twist it off the frame while its just standing there. Or perhaps not standing in some cases!
Just been under my own frame for a good look. The brackets are small and only weld to one transverse frame tube that's about 1" in diameter. They don't spread the load of the stand into the frame by spanning two or more tubes as is more common. Worse still is that the welding fillets on both frame brackets are at best 4mm. That's for a length of approximately 50mm (25mm each side of pivot centre) - about what would be adequate to secure good a battery box!!!! Fact the brackets did not abut tight to the frame before welding in the jig means the strength of the already inadequate welds is very weak. The shame is that the flip side of the brackets on both sides of the frame don't have any welding at all. Yet abut the tube they should secure to quite well. That would be the perfect place for good standard welds to have been made at the factory. But not to lose hope. Well hidden if Triumph now decide to rectify frames with adequate welds before they start to crack off though.
Hmmm, I need to go fit a center stand right quick and hope it breaks so I get Triumph to offer me a Cup for a replacement lol. Never liked center stands, anyway, I hope Triumph makes this right for you OP. You should be offered a new bike in my opinion.
Does all of this also mean that I'm going to have to stop sitting on my bike in the garage, making engine sounds while it's up on the center stand????
Close inspection of the center stand brackets on my T120 show them to be welded to a single cross tube, like the arrangement on the ST.
I also notice that the forward portion of the T120's left muffler (silencer) has a bracket which attaches to the left center stand bracket. It doesn't seem to provide provide much additional rigidity. It does look like that if that left center stand bracket fails at the weld, it'll tweak the muffler something fierce.
1 - 20 of 170 Posts
