I am looking for the Torque setting for the frame bolt (Speed Twin) so that I can install my Meerkat X pipe. If anyone has the service manual page that would be great.
Discussion Starter #2
Have to loosen the left/right side frame rail and engine bolt so that encompasses various bolts.
I believe the frame bolts are 40Nm however I have read others are referring to also loosening the crankcase bolt which appears to be 105Nm.
Thanks, Andrew. I just put that info to use installing a Meerkat crossover!
