Oil inside the combustion chamber isn't a good sign but of your rocker cover gasket is leaking oil into the plug hole as you undo the spark plug you will get that illusion of an oiled up plug? Was she running rough before you removed the plug ??
Sent from my Motorcycle iPhone app
