1 - 11 of 11 Posts
anyone know what years of forks will fit on a 1970 T-120r triple trees! im kinda wanting to put disc brakes on it if its possible not worried about mix matching years just want the best performance i can get!!
I never said the 68-70 forks would work with disc brakes, although ANYTHING can be made to work with anything else if you have some ingenuity, decent tools, and materials to work with!
Basically, I answered the first question about what fits the "triple trees". easier solution is buy an entire disc brake front end INCLUDING the yokes and pop it straight in with the appropriate bearings.
The standard Twin L/S brake as fitted to 69/70 yr bikes was just about the best front brake Meriden ever fitted unless you went to the twin disc option of the T140 range. The twin L/S design stopped as well as the single disc and had more "feel". Just make sure you have the best modern brake linings and modern tyres, the brake set up correctly and you will have a surprisingly good brake.
If you do intend going for a disc setup, Triumph did build a small batch of disc braked T100R which were intended as a 500cc version of the T140 and were referred to as the T100D. Believe these used the standard T100 frame (non-OIF) with the T140 forks so the match should be possible
I was talking to another Brit bike friend the other day about the Twin LS brakes on 69/70 bikes. He said somebody makes or maybe made is now appropriate, a more rigid backing plate for the shoes that gave improved braking. Anyone know about that aftermarket backing plate and if it is still available?
regards,
Rob
Definitely go with Vintage Brake. In fact, if you can go without vital parts long enough, or suffer through the season and then send stuff off to them, let them do everything. The non-conical 2LS front brake setup has tons of potential and they can make it amazing. In fact, maybe have them do the rear while you're at it.
1 - 11 of 11 Posts
