1 - 10 of 10 Posts
I ordered a set of Chris 'Deuce' style turn signals, only to discover that, because of the shrouds, the clamps won't fit. My alternative it seems, is to get THIS from Ma's Cyles.
Anybody run across correctly sized clamps that will work?
Brent's are designed to re locate the pumpkins. The threads from the Chris Deuces, don't match up.
Hadn't thought of that.
Difficult process?
Discussion Starter · #8 ·
Gee, even a dork like me might be able to do that!
Kuryakyn makes nice clamps for their bullet signals. Maybe with a "metric cruiser" adapter they would work?
Just a thought, YMMV.
Discussion Starter · #10 ·
I don't think so Dr. If I looked at the same thing as you-they have clamps for 39mm, 41mm, and 49mm. The America diameter, with the shrouds is close to 60mm.
At this point I'm leaning to go with the piece from Ma's. Reading up on lowering the forks gives me pause from a riding stand point. I might be more inclined to do it if I was going to lower the rear end as well.
Appreciate the input, all.
1 - 10 of 10 Posts
