Status
Not open for further replies.
1 - 17 of 17 Posts
Sinned against the Triumph bible; the word.
- I reused an oil drain plug gasket six times.
- I reused the seals and bearings in my wheels.
- I put on over 4,000 K's on a tire plug.
- I changed my mufflers and did't rejet.
- I used my accident helmet for another year.
AHHHHHHHH ! That feels better.
Didn't re-jet!!!
You had better be ducking from thunderbolts...
:eek:
I didn't rejet either. Even after installing the Cibie headlamp. But just this week I did shim the needles 2 shims. Runs a lot better. Got rid of a mid range hesitation. Just fiund some old washers I had. They measured .022 of an inch. Close enough. .044 total.
At work we never change the drain plug gasket. Unless it gets split.
Confession always clears the conscience. On to another year of bike sins.
WARNING:
This motorcycle must be taken to an authorized Triumph dealer for all service. Any tampering violates the Law. This motorcycle, if not correctly repaired with authorized parts by authorized technicians, with authorized tools, may cause an accident that may result in severe painful injury and/or prolonged death with gnashing of teeth. Blood, broken bones, severe soft tissue damage, multiple festering wounds, oozing puss, sequential arterial spurts as the heart pumps it's last drop of blood, and unpleasant maggots.
On 2006-12-13 08:09, modre wrote:
WARNING:
Never heard of such foolishness...where'd you get an idea like that?
[/quote]
[/quote]
The Gospel according to Hinkley
Dang, I resued a oil plug crush washer ONCE and it dripped.... :evil:
Gone ahead and spent the 3 cents for new one every time since... :wink:
Normandy, my son, please say two main jets, two pilot jets, tow needle shims and go forth to dust HD's and all is forgiven. Bless you.
I put on a center stand and didn't re-jet.
I re-used an oil drain washer too. And it didn't leak, nor did my motorcycle self-destruct.
I've probably voided my warranty.
Discussion Starter #16
On 2006-12-15 20:05, Verticaltwin wrote:
cheap, cheap, cheap..............cheap!
Not so, there simply was nothing wrong with the parts.
I changed my headlight and put some chrome stuff on my bike-is that OK? Did not rejet.
YOU BETTER use the OIL amd Filter the Triumph dealer sells or your engine will blow within 50 miles!!!
1 - 17 of 17 Posts
Status
