Hi all,
My 1966 Bonneville suffered a seized big end, resulting in a bent rod and a damaged crankshaft journal. I've acquired a 1971 crankshaft with rods, to swap in. Apparently the crankshafts were the same from 1963-71, part # E4646, so this should work.
However the flywheels were changed repeatedly over the years:
E4479 (1963-64)
E 5783 (1965)
E6327 (1966-67)
E7332 (1968)
E9687 (1969-70)
E12425 (1971-72)
I understand the flywheel weight was lowered for 1966, and raised again at some later point. Questions -
- Does anyone know the differences between all these varieties?
- I can keep the 1971 flywheel on the replacement crank (easy), or replace it with the flywheel from the 1966 crank (work). Which is the better option? Pros and cons?
- Are there any balance implications? Did piston weight change between 1966 and 1971? How does the weight of a new Emgo piston ( which I plan to install) compare with the old stock ones?
Thanks,
Dave
E4479 (1963-64)
E 5783 (1965)
E6327 (1966-67)
E7332 (1968)
E9687 (1969-70)
E12425 (1971-72)
Thanks,
Dave
