Probably a little too low rent for you Bonnie types
,but here's my flyscreen.
Total cost: About 6 bucks.
Vintage racing number plate & zip ties= Scrambler cred!
It works too.It's a little taller and wider than most of the commercially available
ones.The wind hits you at just below the chin,and stays off your chest at highway
speeds.I think it makes a big difference in comfort on the highway. You can tuck down
behind it into a pocket of clean air,and even at over the Ton,it creates a little
bubble of relatively still air. It could easily be trimmed.I cut about an inch semi-circle
out of the bottom to match the curve of the headlight shell.It's easy to adjust the
pitch too.Just twist it up or down.
I'm going to work on some more permanent mounts one of these days.
:beerchug:
Cheers!
Bruce
