Since I have carbs, I presume that is what caused the following to occur:
After parking my Tiger I noticed that there was fuel on the ground, leaking out of the airbox!
I turned off the pet-cock, I let it sit over night and rode it the next day to work without issue.
I went to start it to go home from work and discovered another fuel puddle below the Tiger and this time it wouldn't start.
The engine didn't even turn over - I presume that it was hydra-locked by the fuel that leaked thru the carb and it's (possibly) stuck float.
SO - I parked it in our office garage, went home, got tools, removed seat, fairings, tank, and spark plugs. Turned over engine blowing out hydra-locked fuel, reinstalled spark plugs, reinstalled fairings, tank, seat, etc. and it started right up! (all under 2 hrs thankfully)
Getting the fuel tank bolt holes to line up was a chore - that is why I used a ratcheting tie down to persuade it into place -see photo.
My brother has a GS100 and they RECOMMEND turning off the fuel line whenever one parks! I am adopting this practice; I will turn off the pet-cock so I don't get stranded.
Any others ever have this occur?
I suspected as much @lobout .
I am dreading another carb rebuild (by me) since those Heed crash bars are installed - they prevent damage to the bike but also impede the side panels, carbs and head removal too!
Heed bars were of no real hindrance to removing the carbs.
Removed carbs, went to a friends shop and discovered that the L carb was leaking.
Put new float in - noticed that the "O" - ring on the old float was deformed, the float didn't appear to be damaged but was replaced anyway. Kept old float for spare, the new one cost me $70USD delivered - the nearest Triumph dealer is 90 miles away.
NO MORE LEAKING!
I'm getting good at taking apart and putting together this Tiger! I can have the carbs out in about an hour and put it back together in about the same amount of time.
