Hi Guys.
Just fitted my new airbox , new plugs , new open exhausts ,balanced carbs. on 96 Speed Triple.
Only got a quick test, but now theres a small dip in the revs from just above tickover to around 2000 rpm.
Im thinking its the pilot screw i need to adjust .
If Anyone any experience in this area, i would be glad of the help in how to adjust or ideas.
check valve clearences.
Did it already have open exhaust system? if not you may have to up the main jets and pilot jets.
I thought screwing out pilot screw would make it eaiser start.
Screw the pilot screws all the way in counting how many turns, don't be heavy handed just to seat them...the unscrew them, you will want 2.5-3 turns out depending on your set up ;-)
Cheers
Mot
