A
Guest
my 02 955i speed triple is fitted with the high level Triumph carbon race can and has a flat spot at about 2500rpm. Most of the time i just ride arount it (these revs dont do the can justice), but when it hits its very annoying. I read a reponse in MCN that this could be cured quite cheaply - anyy suggestions (I'm assured it has been re-mapped accordingly, and its just the same with the std can fitted.
Is this an attempt on a joke? Have you ever seen a motorcycle that doesn't have a flat spot at 2500rpm?!
Here is a hint - keep it above 3000, preferably 4-5k, there is where it lives.
My 955i pulls like a demon possessed from tick over up to the red line. There must be a problem somwhare, knackered plugs maybe? What plugs you lot use? NGK used to be highly thought of????
