1 - 11 of 11 Posts
I am looking for the best operating flashing brake light bulb. So far I have seen two types. One that looks like a halogan bulb that flashes on and off after initial brake action. The second was an led multi bulb that rotates as the runniong lights are on, then flashes on and off for a couple of cycles. Any data on either one or, another model would be helpful. I want the most visable light I can fit in the tail/ brake light.
can't beat a kisan, been running one for about year or longer
I have had very good results with the Comagination brake light flasher. Have installed it (plus the head light modulator) on all my bikes for the last several years with no problems.
http://www.comagination.com/bflasher.htm
+1 on the Tailblazer, plug and play, and it comes with a spare bulb. I've had mine a couple years.
my Kisan Tailblazer 20W-D just rattled itself to pieces after a year and a few thousand miles. Worked well until now. I'm debating spending another $50 for one.
My TailBlazer--the one referenced in my 2008 post above--still works, with its original light bulb. I check it before every ride.
1 - 11 of 11 Posts
