1 - 11 of 11 Posts
Hi All!
Just got my T120 2017 and decided to customise it. Not going to get into all details, but I’ve bumped into an issue woth the led lights and cruise control. The lights I want A9830104 aren’t suitable for my T120 apparently. Plus, as I understand the light somehow are connected to the cruise control. So for the version i would go for i would need to buy specific cc A9630248. The question is - what all this compatibility fuss is about? Difference in pins? The incapability in ECU? Smth else? Would appreciate any thoughts on this. 🙏🏻👍🏻
I don't think there's link between the headlight and CC, I think its just because the cruise control kit replaces the LH switchgear so you need the correct version, DRL or non DRL.
If you search on here there is a DIY cruise control option although if you have to change the switchgear anyway for your new light then you may as well buy the CC one.
  • Like
Reactions: Juri
That makes complete sense and I don’t mind buying both the led and cc. The question then is - why dealer is saying that my t120 is incompatible bobbers led headlights.
2017 Triumph T120
Maybe the differences in headlamp size and mounting brackets?
  • Like
Reactions: Juri
2018 Triumph T120 2020 BMW R1250R
So your question is whether or not the Bobber headlight A9830104 will work on your T120? I have a T120 and the Bobber headlight looks different to me than a T120's. Its apples to oranges. Anything can be made to work but I think in this case, it isn't worth it.
Instructions for the Bobber headlight install showed me the difference. Take a look here... https://www.triumphinstructions.com/ProdDocs/A9830104-US.pdf
FYI - I changed my T120's HL to an LED one for way less than this Bobber one...
Discussion Starter · #7 ·
Thanks a lot! This is really helpful! 🙏🏻🙏🏻 Which LED did you change to? Original or custom?
I used a JW Speaker 8700 Evo 2. My particular one is discontinued, but there are newer ones. It is a 7 inch replacement for a factory H4 headlight.
The T120's headlight 'housing' is a little larger in diameter than 7". So a regular 7" headlight will not fit/work... unless,
I used a Motodemic adaptor ring which allows the use of a 7" headlight... Triumph 7 Inch Headlight Adapter Ring • MOTODEMIC
Discussion Starter · #9 ·
Thanks! Will look into motodemic option.
2017 Triumph T120
I went with the JW Speaker LED headlamp as well but I prefer the looks of the Triumph LED lamp. Triumph fitted the Thruxton TFC with a LED headlamp that would probably fit in the T120 bucket but they don’t offer that headlamp as a stand alone part or accessory.
  • Like
Reactions: Juri
Discussion Starter · #11 ·
I think, I’m just going to go with bobber led light on my t120. The headlight is 500-600 dollars. Might as well add another 200 give or take to get the bobber bowl and other fittings. The thruxton led looks ok and would be cheaper. But IMO bobbers light does look so much better 🤤
1 - 11 of 11 Posts
