Hello everyone! I need some help. Right now I have the wiseco 904 kit with the airbox eliminator with K&N filters, D&D reverse cone pipes and stock carbs. The guys at the place where my bike is getting fixed are having a hard time getting the proper jetting combination:confused: The bike is giving a lot of hesitation and popping on acceleration!!!
If anyone has this combination of performance components can you post your jetting combo that works for this set up.
Thx in advance
Thx in advance
If I remember right, when I had stock carbs I believe I was running 42 primary and 148 mains with my 904. Air screws were 3 to 3.5 turns out.
if you dont have any shims on the niddle it may need some
Forgot to add I was running 1 shim also. when you get some money saved up you should really look at getting some carbs. I couldn't believe the difference they made!! The bike even sounds different.
