Just got back from my handling test.My normal, run a hundred times, backroad ride. My bike before,had ultra quick steering,requiring lots of input to follow a line through a corner,as in always wanting to turn in steeper and tighter as I went around. The new setup only responds to the bar input given.No more or less,it just goes around without drama. The corners were taken at the same speeds as before,only just where I wanted it to go..The ride on the freeway though,is much smoother and steady.A passing semi will barely push the bike off line.I like it.
