1 - 20 of 20 Posts
I just recently went to Naps and want to fill the holes left by the stock mirrors . I've seen the NB / Bella solution but way to pricey.
I also know that I can just run down to the hardware store and throw in a rubber plug :skeptical:but don't like the look.
Please share your Hole filling Mods and remember a picture :photos:is worth a 1,000 words.
2005 T-100, 1974 Honda CB550, 1983 Sportster Ironhead 1000
"Easy peasy, Japanesey...."
Simply remove the two allen bolts on each side, turn the mount over, and replace bolts.
Check it out...
I'll have to look at the Bonnie setup, but on a Scrambler, you can just remove half the clamp, turn it over and put it back on. The mirrors would then mount under the grips if you put them back on.
Edit - yeah - just like the pic. The "up" arrows point down.
Edit #2 - looks like that option won't work on a Bonnie. Sorry.
Spoke too soon.
Now I feel like a dope. I didn't realize the Bonnie mirror mounts were in a different position on the controls.
Sorry to TowerGuy and my other Bonnie Bros.
I bet you could find a solution in the hardware drawers at your local home improvement store. I know they have some good looking zinc-coated black allen head bolts at Home Depot. Plastic plugs might do the trick, too.
Discussion Starter · #10 ·
No problem understand the mistakes.
Thanks davec was looking for something less plastic and more beefy looking. I considered that plastic plug but would like to seal it up better capping it off completely top and bottom. keep the ideas coming.
Was thinking of a brass acorn nut on top. I like the retro look but I think it would look to much like a patch job for the mirror hole.
i have looking at this same problem and have decided to use the holes for other stuff instead of plugging them . i am planning to use a thingy (bolt?) yet to be found to hang my helmet on for quick stops. i hate leaving my helmet on my seat or putting it on the ground. And the other for a hole , put a thingy in to carry thingys like a thingy to hold my bridge pass or tokens. yet to be created. make lemonaide when you get lemons
Mybe I'm a sucker, but I like that little plug that Newbonneville sells....Gives me somewhere else to put a lil Union Jack :))
I tried the automotive plastic plugs, but didn't like the look so much. I ended up just going to Ace Hardware and going thru their nuts and bolts section and found a good setup that way.
But those plugs from Joker Machine look awesome..
Discussion Starter · #19 ·
Thanks all, keep em coming
I must say I do like the Jokers but a bit pricey and I would like to use them holes for something.
How about a DIY Bracket for a GPS or camera mount . Hmmmm
Then for you retro red necks .... twin CB antenas:Cigar:
1 - 20 of 20 Posts
