I've been given this to build for a friend . The mechanical stuff was straightforward enough but the electrics are a nightmare . I think it's been converted to negative earth .
Handy would be some clarification of the original bike's year, as all the original bodywork is gone, the ignition switch(?) appears to be '66-on, it and possibly a lighting switch(?) are in the 'naked model' position on the sidepanel, but the headlamp shell has the '68-'78 lighting switch ...
Frame number should be on the left-hand side of the steering head, engine number should be on the left-hand crankcase just under the cylinder block (just behind the lower exhaust pipe ...). Both are probably a five-figure number (hopefully the same) prefixed by "H", all either prefixed of suffixed by "3TA" if it is. You can post them on the Forum or in a private "Conversation" to me.
Knowing where to start, the electrics on these old heaps are pretty simple.
Not a big deal in itself, electrics still work exactly the same, just the battery negative terminal has been connected to the frame whereas originally the positive terminal was connected to the frame. Problem for original components like rectifier and Zener diode but, if the electrics have been converted, those components won't be in use (present?) anyway, later components work independently of 'earth'.
If your friend uses the bike, unless he want a burns study on his left leg, he'll need a heatshield over the pipes at least in the area above the footrests. Amhikt ...
Hth.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
