First off, I know I could remove head to check. That's for me a lot of work. Tank, rockers, exhausts, removed too. Head gasket replaced, several retorques and setting valves. Add to that, if it is curved, removing valves, going to a machine shop. Then all reassembled. I'm, tbh, losing interest. I get one ride in then next ride something else 'occurs'.
1000 miles ago I replaced the composite head gasket with a new composite. (At the same time I fitted new rings and honed the unworn standard bore cylinders.)
I didn't check the head was flat when I did that, I'm fairly certain. It seemed the gasket was leaking between cylinders. Since then, I've retorqued several times at appropriate intervals. And meticulously ran-in new rings.
The bike has run extremely well since the new gasket and rings. (baring the other unrelated issues that arise). Plenty of power, easily go up to a speed I feel too fast, 90mph, with more to come. Great acceleration, with engine sounding sweet at idle and a nice crack when revving up the dial.
Three weeks ago did 130 miles round trip, with long stop at destination. Warm day, not hot, never stuck in traffic, no worries engine overheating. Stopped couple of times home for few minutes . Engine started hot great, tickled of course.
Got home. Cup of tea, etc. Maybe an hour later, maybe less, decided to do trip to shop. Engine had a little warmth still, not much at all.
Can't remember if it started well, but as soon as I took off engine sounded rough, and had little power. Probably ride half a mile, then turned round and headed home. No improvement during this time.
Bike idled fine, getting home. Walking to back of bike, could hear cracks in the exhaust note. Seemed equal both pipes. Revving engine made this cracking louder, as of course the general exhaust volume increased.
I retorqued head. Checked for air leaks at carb manifolds. Taps give very good flow. No debris in carbs. Not electrical I'd guess, problem isn't sporadic, cylinders are firing. E.I. fairly new. No ancient wiring.
Something happened in that hour the engine cooled. I'd guess the cylinder head contracted, and now there's a leak at gasket.
I've checked compression. Is a bit less, equal on both cylinders. Oil in cylinder didn't increase compression. However, I'm not confident my guage reads well, has always shown low compression even when obvious engine is okay. I have no compressed air supply, so can't do any leak down tests.
However, seems very likely it's a leak between the cylinders.
Is it know for a composite gasket to fail so soon, all else being okay?
When I replaced head, used same thickness PRT seals. Gap before compression was about same again as gasket, i e., 1mm.
I don't see the carbs playing up in that hour. They were thoroughly cleaned several times a thousand miles ago. I use nearly always ethenol-free fuel, although didn't on last trip. Fuel is fresh, worked normally on long trip. I've been getting 60+ mpg.
Checked carbs. Washers at base of springs flat in slider. Fat o-rings ok. Crossover hose okay and recently replaced.
