In case anyone is interested, I thought I would comment on my opinion of my 2017 Explorer. I got it after the 2018's came out because it was marked down to $13,500 and I did not feel the 2018 was $7000 better, plus the 2017 came with the paniers and top box included. The model is the XRt. I have added only a skid plate and bar risers to the bike since new, no other accessories. I am 5'7" and weigh about 170 pounds if that matters, I like to know that when reading reviews.
I am no review writer, so this will be pretty basic list of the good and the bad, if you have a specific question, let me know and I'll be glad to give you my thoughts. All of these are my opinion so take it for what it is worth, which is really nothing, haha.
Bad:
Occasionally the TSAS system acts up and does not seem to settle down. I would say about a dozen or so times this has happened, and turning the bike on and off typically resolves the issue. Not a big deal
The seat started to tear apart this past summer, Triumph warrantied it 100%, so I have a new driver and passenger heated seat now.
The windscreen makes a crappy noise going up and down, this doesn't bother me, but just wanted to note it here, I have had no issue with the functionality of the screen, just that it is noisy. This is actually a great feature on the bike.
The heat from the motor is pretty ****ty! I live in the desert southwest and all bikes suck in the summer, but anything over 80 degrees here, the heat is pretty bad on my legs. If I am fully suited up in riding gear it is less noticeable, but in dungarees or any other pant, it is pretty darn hot. The bike heats up pretty quickly too in stop and go traffic and when the fan kicks on, it blows even more heat your way.
The off road traction control can be a little too engaging at times, however most of the time it is a huge positive, so it will be on both lists. I have ridden other bikes where you can adjust the TC (Honda AT and KTM 1090) and they are a big improvement over the Triumph TC
It is very heavy to pick up, the weight is not very well distributed for this bike, likely due to the big triple in there, but a lot of weight is up high vs the KTM of BMW bikes...this is an issue for me with an aging back. I have seen triumph videos of them picking this bike up 1,2 3, but that is right on the ground in a parking lot for the gut to demo for you. Pick this beast up in sand or on a hillside and it is a different story in the real world. The Tiger 800 is only 75 pounds lighter, but much easier to get up (my wife has this bike, so I have experience there as well - it too suffers from some heat issues, though not as bad).
Good:
In my opinion this is one of, if not the best looking large ADV bike out there. I feel similar about the Tiger 800 in that class.
Very strong motor, just outstanding and so smooth. This thing can run all day and it just feels like it can go on and on forever. So far there is just over 22,000 miles total (4000 off road) on the bike and it feels better than new.
Super comfortable for all day riding, really, just super comfortable on the road, the ergonomics work for me very well in the high or low seat position.
Ride modes all work great and are pretty much perfect for the specific mode. Off road TC is really good, (not great as noted above)
Off road ABS is excellent, I can point this big beast down a loose rock filled hillside and grab a fistful of lever and pull as much as I want, that wheel holds straight.
Easy oil changes
Headlights are outstanding, very bright even in the low beam setting and I like the little adjustability they offer for when you are loaded down and the beam can be lowered a bit.
Some of the negatives do not bother me much, just pointing them out, as there will be something with every bike I probably would like to be different. Overall this is one of the best bikes I have ever owned and I have had quite a few. I love it for touring across the country, daily commuting and taking onto the dirt roads. However, the heat from the motor and the top heavy nature of this bike (only when picking up, it is relatively nimble for a 575+ pound beast) are pretty big negatives for me. These two factors will be guiding me in a different direction on my next bike, but my needs have changed as well and if I didn't do any off road riding this would be great...though the engine heat is definitely a factor and I am sure more so here in Arizona.
Bad:
Good:
Easy oil changes
