1 - 7 of 7 Posts
I can buy a set off tor exhaust for a roadster. This are 2 mufflers. They are made for a 2010-15 roadster Will this fit my 2005 rocket. Or is this to difficult to fit. I have now the original 3 pipes exhaust
Verstuurd vanaf mijn LG-H930 met Tapatalk
If it is just the muffler, not the full system, it should fit. Footpegs and rear brake master cylinder are different and in a different place so the full system may not fit.
If you have the original cat or the oem cat bypass, there are still 3 connections. I don’t see how you get 2 Roadster mufflers on. By the way, you still may be able to buy the 3 muffler Dave Platt cat bypass:
So i need the roadster cat as well. I gonna look for that.l like the 2 pipes system.
I found this pipe for a touring. Would this fit my rocket 3. And when it doesn't. I like to know why not.
Not sure if ti will mate, looks different to my crossover. I am not at home so can't have a good look for you
Maybe just take the chance. How much can it be different
1 - 7 of 7 Posts
