Not in the least bit without major modifications to the chassis for mounting along with many other things. You're looking at a ton of work, and if you don't have the ability to tig weld, you'll be paying a shop a hefty amount to have them jig everything up to where the weight is in the proper place, final drive is aligned, etc., and weld it all.
Out of curiosity, if you were to go to all that trouble, why not use a late model 955i engine? Is it to get away from injection?
