Hi All,
Following @Andytheflyer's rebuild in 73 TR7RV in a 71 T120R frame restoration, I'm curious to know if everyone else rebuilding 750 twins also simply bolts engine components back together, or if anyone checks parallels and perpendiculars, or if anyone has checked 'em during a rebuild and found 'em accurate on 750 twins?
Reason I ask is, rebuilding Japanese engines in the past, I'd always just bolted 'em back together, never knew there might be inaccuracies but never experienced a problem. Otoh, long-time reading of particularly John Healy's, @Truckedup's and @speedrattle's posts on BritBike, and some experience of manufacturing cock-ups in triple engine components has me interested in what others do.
The discovered problems I've read of, and I wonder if anyone checks for:-
. Crank, camshafts and/or gearbox mainshaft axes not parallel.
. Crankcase cylinder barrel mating surface different heights on different crankcase sections.
. Crankcase barrel mating surface not parallel with crank axis.
. Conrod big-end and/or small-end oval.
. Conrod big-end and small-end not parallel.
. Conrod over-length (0.1 mm. over-length indicates failing conrod?).
. Conrod not in centre of bore.
. Cylinder bores' axes not perpendicular to barrel base mating surface.
. Cylinder barrel crankcase and head mating surfaces not parallel.
. Skimmed cylinder head.
. Cylinder head barrel and rocker-box mating surfaces not parallel.
. Rocker-box cylinder head mating surface not parallel with rocker spindle axis.
