As a new owner of a Thunderbird 1600 i am looking for some advice on engine noise. So, bike has 1800 miles on it. Broke it in by the book,got it serviced at 500 miles. The day i was riding it home from the dealer i noticed a light rapping nosie as 3K RPM was approached. I wasent pushing the reves any higher due to the break in period.
At the first service made the dealer aware, was told no problems found. Now i am riding the bike in the 2500-3500 range and the rapping knocking noise is audible under light acceleration from 2800 RPM on up. At idle no noise. however i have obsessed over this to the max and spent last night out in the garage listening to it with a stethescope. with no load slowly bringing the RPMs up you can clearly hear it clacking from the right side cylinder wall. To me it sounds like piston slap or a loose wrist pin. Any succes with dealers fixing this noise for anybody. I have read all the other noise postings and noises usually get blamed on the valves adjustment, cam chain or decompressor mechanism.
