I just checked the air filter on my 02 S3. To do this you have to remove the fuel tank. When the tank was off, I turned on the ignition key to check on some other bulbs I replaced.
Since then, the engine light stays ON. I guess the ECM couldn't find the fuel pump and turned ON the engine light. How do I turn off the Light ?
Thanks in advance.
[ This message was edited by: Mossy21 on 2006-11-14 21:25 ]
Thanks in advance.
