If I read this right compression ratio for your bike is the same as mine @ 10.6 to 1
and 1 being atmopheric pressure then you should get around...
10.6 X 14.7=155.82psi or Kpa being 101.4 X 10.6= 1074.84Kpa
It's not exact but it should give you a ball park figure.
Squirt a little oil into each cylinder and make sure throttle is fully open.
Do another test.
I'm no expert on this, but there's a flaw in calculating real or effective compression in this way that I've read about.
The 10.6:1 & all published comp ratios AFAIK are stated based simply on cyl volume at BDC & volume at TDC. So far so good, but in most engines the inlet valve is still open at BDC - on these T3s with 'green' cams, it doesn't close until 50 deg after BDC.
Of course at normal engine running speeds a number of other factors are in play to determine actual cylinder filling with mixture.
But at the low cranking speeds of a compression test, I believe that there will be significant leakage back out the inlet valve as the piston initially rises from BDC to TDC with the inlet valve open. Hence the compression measured in this way will always be lower than the published figure.
With my limited knowledge on this, to me, what others have said about the numbers being very close across all cylinders (& not too low) suggesting all is well seems the right interpretation.
I guess this suggests the OP's oil burn/blue smoke issue (from another thread) has to be the valve stem seals - maybe from being a bit dry &/or hot from a low oil situation?
