Another question from this weekend's teardown (2006 carb T100)...
  1. Engin Casing hole (please excuse the rusty chain!) - seems like something should be bolted in here. Any idea what's missing, or why it would be removed?
  2. Electrical Connectors - I've removed the tank, and have these two cables underneath - any one know what these are for?
Thanks all - stay safe!
Casing hole was for a plastic cable clip, it was deleted after the cables were re-routed some time after 2004.
Thanks fullplat1.
Anyone have any ideas on those electrical connectors? They were under the tank, and didn't seem to be connected to anything.
Thanks fullplat1.
The large connector is for the EVAP system, only fitted to California models. The smaller connector is the 12 volt accessory connector (USB phone charging/cigarette lighter socket etc.).
Thanks so much Ripper!
Be careful with the accessory connector, it is subject to dirt and causing the fuse to blow. I snipped mine out and insulated the wires with heat shrink and tied them back onto the loom.
