Just curious if this is normal or a symptom of something wrong. I have an '04 Daytona 955i and I have just changed the oil, spark plugs and fuel filter.
The bike idles fine and if I roll the throttle the rpms climb nicely. But if I crack the throttle open quickly then the engine bogs for a split second, the rpm's drop and then it fires to life.
It seems as though the fuel system is having trouble supplying fuel too quickly. Is this a symptom of something wrong? Could it be the fuel pump? the fuel pressure regulator? How can I check?
Thanks in advance.
Thanks in advance.
