1 - 18 of 18 Posts
This is what im trying to produce in .020 or .040 gague steel.
It's a simple design that shouldn't cost me 384 dollars!
Can anyone suggest anything to reduce the cost or is anyone willing to produce this shape for me in their home mill?
My tolerances must be within the 100th's of an inch.
If you can produce this piece for me please let me know, I have the means to draw it but not machine it. :(
--Kory
That's crazy. I've played with their tool but never ordered anything through them. Maybe you should just call around to some local machine shops??
Your problem, of course, is "quantity 1".
Laser cutters are everywhere and perhaps more economical. The tolerances might not quite be tight enough the that laser is pretty sharp!
A laser cutter can handle that easily. Find a local shop with a machine, give them the profile electronically and it's done.
TTR, call around your neighbourhood. That is totally crazy for a price. You have already done the work so a waterjet of a lazer cutter would do the job.
Machining
Kory
I can do the job for you (no charge) just email me your drawing. I could get to it next week and then mail it to you. What material do you want it made of?
Within hundreths???? Of inches??? That could be done with a tin snips and a metal punch!. Within a couple of thousanths then maybe you would need a machine for it but nothing like that price. A person could scribe it carefully and cut it with snips... I'm serious. Especially if the steel is only .020 thick.
The drawing is missing the radius of the hole pattern though ...
Discussion Starter #9
Kory
Wanted to publicly send a big thank you to Zulu for machining me this part, I don't have it yet but he sent me a photo that I'd like to share.
I sent him the autocad file and he used a Wire EDM machine to CNC machine it.
I'll post pics on where this support bracket goes once my Luggage Locker comes in.
--Kory
Discussion Starter #11
Ok part is on the bike finally!
My luggage locker tank bag came in today, so let me explain what this thing does.
http://www.luggagelocker.com/tank-locker.htm
Leslie's product is really great but over the years weight in the bag will cause the bolts to pull down into the plastic ring eventually pulling through it.
This piece spreads the weight over the metal strengthening the ring.
The bags zippers can even get locked closed:
http://c4.ac-images.myspacecdn.com/images02/38/l_ba69a203787b43618f3ef8c88a49a5db.jpg
Thanks for reading, and thank you for the piece Zulu!
--Kory
Easy Kory,
It wasn't off topic. As a matter of fact it was showing off a system that is like yours but takes a lot less work and time to put on than the system you modified.
I don't think Aimu intended to take anything away from your project but to add to it.
Discussion Starter #17
Sorry, bit of my Scottish temper coming through.
The poster posted a different companies bags that is completely unrelated to this product or even my project.
I feel he's hijacking my thread...
Mods... you make the decision.
--Kory
1 - 18 of 18 Posts
