Fwiw, think I might've worked out your bike's weird "Rear strap" (and battery carrier?) ...
Thanks StuartHi Eli,
'66, Triumph went from 6V DC to 12V DV electrics. However, while the vast majority of 12V bikes had a single Lucas PUZ5A 12V battery, early '66 12V bikes had two of the earlier MKZ9E 6V batteries connected in series, these two needing a bigger carrier than one PUZ5A.
Regrettably, I can't find a picture of the relevant Rear strap (F7086) to compare with your photos. However, if you enter "triumph 82-8024" into your preferred internet search engine, it should return images of the correct '70 twins' battery carrier. Note particularly the vertical back and front:-
. if one or both on your bike just slope from the bottom to the top, likely it's a PUZ5A carrier that's been mangled to fit;
. otoh, if the carrier on your bike looks anything like this:-
... particularly the stepped rear, it's a 'two-MKZ9E' carrier that goes with the Rear strap fitted.
Hth.
Mmmm ... that it hooks over the two "straps" and those bends are smooth suggests it's original Triumph. However, that its back has been bent to reach the Rear strap and it lacks the horizontal slots in the front and back for the later rubber battery securing strap suggests it was originally intended for the single 12V battery and it's earlier than '70.Mine looks like a homemade carrier cut out of old tin! I'll order the correct one shortly thanks to you kindly pointing this out and providing the parts number.
Thanks Mick. So just torque them back up when refitting, no need to worry about the head distorting?Up to and including '70, you need to take out the 2 long head bolts that mount the head steadies, along with the 2 small rocker box bolts and the 3 nuts underneath.
Assuming the correct 8" version, should be bloody brilliant on your bike - same brake on the front of my T150 (which goes a lot faster and weighs around 70 lbs. more than your bike); while it isn't as good as a disc, it's still pretty good ... and this is with the front brake switch that's alleged to affect the brake ...front brake is still useless despite
next step is to remove the wheel and inspect the shoes
Can't help with the pressure loss but I advise against the valve nut in this position - if the tyre starts to creep around the rim for any reason, it'll drag the tube with it; valve not secured with the nut, the creeping tyre/tube will show first as the valve not vertical; otoh, valve secured as it your photo., first you'll know about a creeping tyre/tube is when the tyre deflates very rapidly, because the valve's ripped out of the tube ...still losing pressure from the front tyre but valve is not the culprit
Fwiw, have a look online and/or in your local bike shops for:-going to give the bike a proper clean
Thanks Stuart. You walked me through the arcing procedure for my 500 and the front brake is a lot more effective than on the 650. I haven't had much time for spannering recently unfortunately but I'm fortunately that the bikes are running well apart from the leaky rocker covers.Hi Eli,
Educated guess the 'restorer' just bunged-in new shoes, never either arced the shoes to the drum or burnished the brake?
"arced the shoes to the drum"
When drum brakes were more common, new shoes or linings fitted, it was common (standard?) to assemble the shoes on the brake plate and turn the assembly in a lathe so the linings were concentric with the axle/spindle. Now, many drum-brake assemblers seem to think this happens by magic ...
Check for failure of this magic by: covering the linings with chalk, spinning the brake assembly in the drum for a few turns with the brake applied then re-examining the linings; risking stating the obvious, where the chalk remains on the lining indicates lining that never touched the drum ...
If the linings need turning but a lathe isn't available, more-time-consuming but equally-effective is:-
. Stick sandpaper around the drum, chalk the brake linings again, assemble the brake in the drum, rotate the assembly for a few turns with the brake applied.
. Risking stating the obvious, because of the dust generated, do this wearing a mask and clothes you can wash straight after.
. Remove the brake from the drum and examine the linings - you should see some of the chalk has been removed by the sandpaper.
. Repeat 'til the sandpaper's removed all the chalk from the linings - then "the shoes are arced to the drum".The workshop manual also advises tapering the leading and trailing edges of each lining by an extra 1/2" length and 1/8" maximum depth.
. Clean out the dust from the drum, remove and discard the sandpaper, clean out the adhesive, reassemble the brake, throw away the mask, wash the clothes you were wearing.
"burnished the brake"
Once the shoes are arced to the drum, take the bike to a quiet stretch of straight road on a dry day. No other vehicles around, I've always done ten stops from 50 mph with a minute's cooling between each, followed by half-an-hour's cooling then ten stops from 70 mph with a minute's cooling between each; however, no idea where I got that from.
Googling "burnish drum brake" for clarity returned links to different sources that recommend "30/30/30" - 30 stops from 30 mph with a 30-second cooling period between each; one also recommended deceleration not greater than 12 ft./sec. (i.e. quite gentle).
Can't help with the pressure loss but I advise against the valve nut in this position - if the tyre starts to creep around the rim for any reason, it'll drag the tube with it; valve not secured with the nut, the creeping tyre/tube will show first as the valve not vertical; otoh, valve secured as it your photo., first you'll know about a creeping tyre/tube is when the tyre deflates very rapidly, because the valve's ripped out of the tube ...![]()
... I've had them for decades on my bikes, clamped between the front mudguards themselves and the "Rear stay" where it passes around the 'guards. Flap's 130 mm. wide at the top, widening to 150 mm. max, 170 mm. top to bottom.
Hth.
Thanks for this. I'm going to make a better bracket than the one I have before the weekend to get it to fit between the swing arm and the center stand.Attached is an old article (2009) from R.F.Whatley detailing a very clean installation below the swing arm area.
I mounted a Tri-Cor (small, vertical filter using the Trident small cylindrical filters) to the vertical frame support, right about where your hand is holding the vertical frame in the picture. It fit well without interfering with anything.
Bear in mind the twin vibes split steel 'guards, ally splits easier ...found a pair of alloy mudguards for sale in France
Thanks Stuart, that's a nice idea.Hi Eli,
Same on my 500.
Bear in mind the twin vibes split steel 'guards, ally splits easier ...You might want to consider mounting the 'guards Japanese-style - grommet through a big hole in the 'guard so there's rubber against both 'guard surfaces and the edge of the hole; steel bush through the centre of the grommet, bush ID for the mounting bolt, bush length slightly more than the thickness of the grommet, so you can tighten the nut 'n' bolt through the bush and any mounting but the bush prevents the nut 'n' bolt squashing the grommet = vibe-isolated 'guard.
Hth.
