Hi Eli,
As you've changed the clutch plates, check clutch operation with the primary access plug removed - Meriden wasn't generous with clearance, adjuster screw hitting the underside of the access plug slot is regular, if it happens when the clutch is rotating, the screw chews through the access plug slot ...
Ime, poor advice as it's hard to tell. I advise:-
. First screw in the adjuster with lots of effort, you'll feel the effort increase as the screw lifts the clutch pressure plate. Back the adjuster right off again. Reason you do this first is you want to be sure the clutch actuating rod is backed up to the actuating mechanism in the gearbox cover (very annoying to do the clutch adjustment and then find the first time you pull the handlebar lever is when the rod moves up to the mechanism ... amhikt
. Once you're sure the actuating rod is against the gearbox cover mechanism and the adjuster is backed off, definitely not still lifting the clutch pressure plate, turn the screwdriver in the adjuster between just thumb and forefinger, you'll be able to turn the screwdriver 'til the adjuster's against the end of the actuating rod but no more.
Back off the adjuster about the half-a-turn or so, tighten the locknut. Done for certain.
Hth.
