Okay, so I thought I should start a new thread to focus on a specific question about my Sprint Sport repairs.
The brake light went out. I found that one of the bulbs was burnt out and that the wiring at the front master cylinder was pulled out so I fixed those issues and now the front brake will activate the light but the rear brake will not.
Now here's the crazy thing. I started doing some testing. There are 3 connections going to the rear light. 1 is ground, 1 is always hot, and 1 is triggered off of the brake switches. When I hook a meter up to the one that is triggered off of the brake switches and I hit the front brake, it reads 12v. When I hit the rear brake it reads 12v. But when I hook the connections up to the lights, the front brake triggers the light but the rear brake does not...
I thought if they were both sending 12v across the wire then the lights should light. I tested resistance and the resitance across the wire from the rear brake is greater (100ohms) than the resistance from the front brake (3 ohms) but if the voltage is the same, shouldn't the light light up the same? I don't get it.
Any advice from those who know electricals would be much appreciated.
