i had ridden my 99 t309 for about an hour the other night when all the lights went dim and finaly the bike cut out??
i checked the output on the alternator and it was around 12.5 volts.
my question is is this normal voltage and if not what could the problem be?
To an extent it depends on what revs the engine was at when you checked it, but anything > 1000 rpm and you should be getting above 13.8 volts from the alternator to charge the battery. It sounds like your alternator may be dying, you ran on battery for a while until it gave up the ghost. What is the voltage across your battery, bike not running?
Thanks for the reply
voltage across the batt was 12.3
if it is the alternator would a unit from a t312 work?
Battery doesn't look too bad, but then a load on it might drop the voltage considerably. As to the swapping an alternator I don't know, new to Trophy's. Hopefully someone more knowledgeable in that area will reply.
Thanks for replying
you wouldnt have an idea where i could find spares for this bike? as you can tell im new to this
Depends where you are, I'm in the UK.
Have a look on ebay, there's a load of different Trophy's being broken and sold off on there.
