1 - 3 of 3 Posts
Quick question. I have a 2008 steel tank Sprint. How do the electrical connectors undo (e.g do the twist and pull down or is there a little dohickey that you press to release them) ?
Thanks,
Sion
Lift the tanks enough and look at the connectors. You will see they've got small platic tabs to be pressed before pulling the connectors. Also, they cannot be mixed up when reconnected. shapes are differents.
1 - 3 of 3 Posts
