guys,
I removed the Ai and found the benefits in the low speed running, as George mentioned in another thread. This in itself is definitely worth doing.
Having done a 'straight through' airbox gutting on a carb'd Scrambler, with considerable gains, I just did the same to my efi Bonnie (they have the same airbox) It goes without saying, but I'll say it anyway: I'm not suggesting anyone does the same, just reporting what I did. ok, erse covered.
The Scrambler required re-jetting and dyno runs to check it, but I haven't done any dyno runs on the T100 yet. I'm rather hoping that the closed loop system on the efi bike will have compensated for the extra air the motor is now getting. I will have it checked as soon as I get the chance, to make sure the a/f is ok, but the bike goes like the clappers so it shouldn't be that far out.
Derek (fieldsheer) changed his exhausts and got about 5hp more, with no efi map change, nor need of it. If I need another map I'll have it installed, but the way the bike goes I don't think it'll need it (big increase from 4,000 to 7,000, pulls hard in 4th from 2,500)
So far, the cost of these improvements has been £00.00, not a bean. The modified standard paper air filter may not be very good after a soaking, we shall see. If so I'll put in a unifilter like I did on the Scrambler.
airbox lhs:
airbox rhs:
modified air filter:
got a tune out of the Ai valve:
http://www.youtube.com/watch?v=hVe27sj7pJI
airbox lhs:
airbox rhs:
