Howdy.
After spending months looking at this forum scrolling through topics and researching mods for my bike I have a couple of questions that I can't find answers to.
I have a 2008 EFI triumph speedmaster with TOR pipes for reference.
1. Are the standard o2 sensors run wideband or narrow band output? These are 4 wire sensors to the ECU.
2. In relation to the previous Q. Does the ECU have an analog input (0-5v) for the o2 sensor?
3. Has anyone successfully run a turbo on a triumph twin that has a 270 degree crank, and did it run ok considering the exhaust pulses are not ideal for turbo application.
4. Does anyone on this site make throttle body and battery relocation brackets? (not paying $300 for an ABRK when i can get the filters and bungs myself)
5. Is there a company that makes aftermarket head gaskets for these engines, e.g. metal compound and in different thicknesses?
6. Has anyone put aftermarket throttle bodies on these bikes without any great difficulty?
7. Is there any gain to be had with head work or is the flow of the head designed well from factory? (other than cams/springs)
8. What is the power limit of the standard pistons/rods on a non-boosted engine? I know that with boost you can run up to approx 8psi and about 85hp.
9. Is there a way to run a gear indicator on these bikes through the factory ECU?
I know that some answers may be in topics but I have yet been able to find them through trolling threads. I am about to start playing with tuneecu and beginning my quest for power. My main problem is the power curve dropping off around 6000rpm (on last dyno), which I plan to fix with filters and more fuel, and I will move the peak torque rpm by using an adjustable intake trumpet.
Any help would be greatly appreciated and I look forward to the replies.
