Hopefully people will read the "Important Tips"
1. You need to Self-welding the side cases Luggages, Different models have its different frameworks.
2. It will fit the models listed above but modification may or may not be required. This item is intended for professional installation(If you can't accept modify your bike,please don't buy,thanks!)
3. Side case Luggages and exhaust pipe need to keep enough distance that it will not be affected by the high temperature of the exhaust pipe.
4. If you want to return the item (cause you don't know how to weld or install)you need to pay for the shipping both ways. Please understand.
I'm confused on what you get and the fact they mention Hepco & Becker in the title.
Looks jenky. $299 plus $100 shipping. $300.....you can find a decent start to good hard sided kit or the majority of soft sided kit.
