Triumph 650 crank balance
In my experience, Triumph got the balance factor pretty much nailed for the general population but dropped the ball when it came to dynamic balancing. They actually could have reversed their reputation for buzzy bikes if they had spent the extra time on each crank assembly. Dynamic balancing makes so much more difference in perceived smoothness than static balancing that they could easily have ignored the static balancing without detriment. I have sometimes sent my cranks to the balancer with instruction not to bother with static balancing.
However when I have, this is the result I got.
50% bf is fine on low compression bikes and 500 pre units. However, the higher compression bikes seem to vibrate ALL the time at the same amplitude but with different frequencies depending on the RPM's(naturally) With dynamic balancing this is redered not very severe but to me it is annoying that there is no RPM range where the bike is perfectly smooth.
58-62%bfOn the recommendations from my balancer(THE hot-rod drag racer balancer in SoCal at the time) this range would serve me best for my type of riding. Bearing in mind that I specialize in pre units, I don't run these bikes too hard, although I have been known to ride them for daily transportation in the greater L.A. area and that means 70mph on the freeway or die. I suspect that these engines would have been quite buzzy at over 6k rpm but I wouldn't know since I never rode them that way. Some of my bikes were electric motor smooth throughout the entire rpm range below 6k.
85%bfThis is what I normally use these days as it serves to not confuse my current balancer. I always upgrade to unit 650cranks for my pre units and they are all 85%bf. The bikes are smooth from start-up but gradually gain vibration as the engine climbs in rpm. There might be a smooth-out after 6k, but there again I don't ride these bikes that way. Tootling along in top gear at 40-45 mph there is no perceptable vibration at all.
Hope this helps.
Bill
Hope this helps.
Bill
