1 - 20 of 23 Posts
Hey guys! I'll cut to it. My bike cranks, has load and compression, has spark (With new spark plugs). Fuel is getting into the bike, no rats nest in the airbox. It seems everything is there for her to turn over, but she won't. I'm at a loss for where to turn next, and am hopeful someone here can help me out.
Can you bump start her?
-Kit
Running out the door right now, but be sure to keep the battery charged while you mess with it!
-Kit
Thats fine! I appreciate it!
One thing I will say is I loaded a tune onto the bike awhile back. It ran on the tune, but it has sat all winter. I haven't started it this season.
Did you put Seafoam or Sta-bil in the gas before you stored it? Have you tried turning the keyswitch on and off five or six times to make sure there's fuel in the lines?
-Kit
Discussion Starter · #7 ·
-Kit
When i looked into the cylinders I saw fuel in them. As for seafoam, I doubt I did.
Try a quick blast of brake cleaner ACROSS the air intake. See if she'll fire up and cut out / idle . It will do one or the other. If she starts and idles great if not and cuts out. . There's gonna be another reason. If you've tried all above and sure all is well, look at immobiliser (if fitted)
As for the map . If she running on the map may be running to rich / to lean and not a correct ratio to fire. Speaking from experience on another it was running to rich and after long standing everything were dry. Too much fuel getting through and kept flooding
Just a thought .
Discussion Starter · #10 ·
It cranks but wont turn over? I
Didnt know that was possible.
Not sure if you're serious? The starter turns the starter clutch but the bike won't turn over.
Just a thought .
Immobilizer? Where's that at?
As for the MAP ill reflash it in a few hours and run some brake cleaner, see if she'll go.
If the starter turns the starter clutch, but the starter clutch doesn't turn the crank... Well, that's engine out and split the cases to replace the starter clutch.
-Kit
Discussion Starter · #12 ·
-Kit
No it DOES crank, I am good on that part.
Sorry but you're still not making it clear. No need to get over complicated.The way your explaining it i would assume your sprag has went out.
What you might mean is that the bike WILL turn over but will not start.
Youll be checking very different things depending on whether the engine is turning over....or not turning over. ( crank and turn over mean the same exact thing.)
-Kit
Well then, with a proper explaination you can get a proper diagnosis.
If you have accurately checked that yoi have good compression, spark, fuel, and proper air flow could have something to do with the sensor that senses when the bike is in neutral.
Discussion Starter · #16 ·
Thought i would throw this in there since i have seen on this forum a few times the person had the kill switch engaged.
AH okay.
Right well the bike turns over but doesn't start. Perhaps that's a better way to say it, I've always said crank to mean turning.
Kill switch is on start, bike is in neutral and coils/starter work. With sidestand up and clutch in the bike turns but won't turn over.
So how do I bypass the sidestand switch and the neutral light, since those appear to be the next culprits.
Immobiliser, maybe you have alarm system?
Honestly try the brake cleaner thing. I had old gsxr 400 I were restoring that I spent hours building and wouldn't start ... brake cleaner short blast across air intake and bingo! Fired right up and idled.
Just another thought are the valve clearance within spec ?
If the clutch or Sidestrand switch were at fault it wouldn't turn over at all. Know this from mine. As soon as you hit the stater button nothing. Clutch in stand off then She'll turn over. So doubt it's either of them. Just my opinion
Just ideas thrown out there to assist. Sometimes over thinking things make miss simple fixes.
This is infuriatingly nonsensical. It is self-contradictory. Can't help you if we don't speak the same language.
-Kit
Dump that tank of old fuel and fill her up with fresh stuff.
+1 on UlsterSpud's post. Old fuel, especially if it is alcohol-tainted, can cause all sorts of problems.
Dump the old stuff, change the fuel filter, and try again.
1 - 20 of 23 Posts
