1 - 9 of 9 Posts
Doing the sprocket change this weekend on a friends son's 675. Do not have a shop manual on this bike as I ride a R3C. Looking for torque specs for sprockets and axle. Also any tips, tricks or opinions.
Straight from the service manual...
Rear Sprocket Nuts - 55 Nm
Rear Axle Nut - 20 Nm
Rear Brake Caliper
Front or Larger Bolt - 29 Nm
Rear or Smaller Bolt - 25 Nm
Output Sprocket to Output Shaft - 85 Nm (Use new tab washer, apply ThreeBond 1347 to threads)
Sprocket Cover to Crankcase - 9 Nm
Seems like a major gear change from the stock 16-47 setup.
I run a 16-49 on the short race tracks and stock 16-47 on the longer tracks.
15-49 will be more suited to stunting the bike than riding it on the street or track in my opinion.
Good luck with the switch...
TripleThreat
TripleThreat
I don't think it's that huge of a change... I mean it is a pretty big difference, but not to the point where the bike is unrideable on the freeways. It's not like a 60 tooth stunt sprocket.
I know that Josh (Shnike) went -1 and +2 and is loving it. After all... we don't have much use for our top end on the freeways, while you need to maximize it for the straightaways on the track ;)
My friend Paul runs -1 front on his race bike and likes it a lot. Pacific is pretty technical, but the front straight is plenty long enough to need some headroom.
Not to threadjack, but what's a good site to go to to readup on sprockets and how changing it affects speed/handling etc...? I really need to start reading up/learning things like that. Same with suspension so that I don't have to keep relying on others to get me set up...
Gearing Guru
This is about as good a starting point as can be found.
http://www.ducatimonster.org/faq/faq_gearing.html
1 - 9 of 9 Posts
