Does this look ok to you? Air box and foam pad
Does this foam pad look to be in good shape? 1st times looking under the tank so don’t know what it should look like.
that is not an air filter, that just cushions the air box to the engine. air filter is inside.
Of course, that is whey I asked “Air box and foam pad” I know it is not the air filter, I asked about the foam pad. Does it look ok?
no it dosnt you need to call your local triumph dealer and order a replacment right away and pay full cost and dont forget the 20% tip to your parts person for working so diligently for you!!!!!!!!!!!!!!!!!!!
if you cant tell im being sarcastic .. its fine
skos,
The main reason for that foam is to 'muffle' the intake honk that would otherwise resonate in that big flat piece of plastic.
Good looks are not required.
Thanks guys. I thought is was something like that. Even bikebandit want 5 bucks for that. That could be the most inexpensive part you can make your self.
