1 - 3 of 3 Posts
3
Guest
my spindle problem is starting to get on my nerves .On the intake rocker spindle i have a weird oil channel for oiling the rockers and on the exhaust side it seems just a hole .mabey because the exhaust tappit is pressure feed , man i dont want to reassemble the rocker boxes without knowing for sure!
Good morning Bond.......... the two spindles you have are perfectly ok to use. The one with the hole is from a 650 and the one with a helix groove is from a 750. On to your next mission!
It is possible that the threads on the end are different, the 650 will definately be CEi but the 750 one could be either CEi or UNF, try a nut on both.
Roy.
3
Guest
thanks but why is the one from the 650 so tight ?When it is not assembled i can blow through it and when its assembled its so tight barely any air gets through
1 - 3 of 3 Posts
