does anyone know if a rear rim off a 2002 trophy, will match up with a 95 tona, they look about the same, just hard to tell from a pic. thanks
It will fit, however the Trophy does take a narrower tyre..170 I think so double check the rim thickness as I'm not sure if that changed or not...apart from that it's fine ;-)
rim
hey ,thanks, semms to be 17x3.5. which is the same as the tona, ,,just wasnt sure is if rotor ,sprocket, axle , would match up, i found a trophy rim for a good price, looks the same as my super111's front, anything is going to be better then the honda rim ive got on there now though. thanks
IIRC, same rim, different tire spec'ed.
-Kit
