I need my 12k service. These Speed Triples are simple machines. This is what they do for $800?
1) Air filter
2) Spark plugs
3) Throttle Body sync.
5) check ECU for errors
6) Valve check and/or adjust
7) Oil change
8) TPS alignment
9) cable adjustments
10) chain adjust
11) rear wheel bearing maybe?
Basically, I only need 7 out of those 10 things done. Do they repack the rear wheel bearing too I hope? Also, I've changed my coolant and brake fluid in the last week so don't need that.
Does $800 seem high or am I just a cheap bastard? I thought all that would be about $350. Let's see $90/hr labor. So that's 9 hours labor? You're kidding me right?
1) Air filter
2) Spark plugs
7) Oil change
8) TPS alignment
10) chain adjust
