1 - 7 of 7 Posts
You can make anything fit with a hammer. Yah those will work if you have some extra tubing, a bender , a welder, and other tools to basically fabricate a new system secondary exhaust system. Let us know how it turns out. :D
I was thinking as a slip on, sort of like the arrow system from triumph. Remove the original ones and fit these to the midpipe.
Buy em and let us know how it works out. If a mid pipes comes with it and the bend is close you can heat it with a torch and bend it to mate. Probably will still have to fab a hanger bracket.
i couldnt believe when i got my wolf cans that I had spent the $$. Honestly, if the tubing is the same diameter it will probably work as a slip on.
I think those come with a new mid-pipe so as long as the sprint and speedy share headers you're ok
Alternatively a local car exhaust guy or any metal worker could make a new mid-pipe for you to suit
1 - 7 of 7 Posts
