I have a speed triple 2012 with arrow twin high mounts.
Looking for a map & im in australia.
What are the difference between these 3 ? It looks like the last one if for AU - Are they all the same just for different countries/fuel ?
20487Map.hex OEM md5checksum Speed Triple 1050 from VIN 461332 to 537880 Arrow slip-on Fuel up to E25 Minimum 95 RON (89 RON/MON) fuel
Replaces the 20461
20488Map.hex OEM md5checksum Speed Triple 1050 from VIN 461332 to 537880 Arrow slip-on Fuel up to E25 Minimum 91 RON (87 RON/MON) fuel
Replaces the 20462
20489Map.hex OEM md5checksum Speed Triple 1050 from VIN 461332 to 537880 Arrow slip-on Fuel up to E25 Minimum 95 RON (89 RON/MON) fuel
Australia, NZ and SA
Replaces the 20463
Certainly different fuel types (likely slightly different fueling and timing for 91/87 vs. 95/89). I am also going to guess that your Australia bikes don't have SAI and those tunes account for that (no engine code for solenoid disconnected, etc). Don't think there would really be any other significant changes.
Thanks for the reply - So id be safe to try out all 3 ?
You could, just make sure to run the proper fuel grade for each, and if you do not have SAI the North America maps will likely cause your engine light to come on for the solenoid.
Other than that the two 89 octane maps should be identical so you won't likely see a difference.
Also, if you need go run the 87 octane map, you can always uncheck the SAI box, save the map then load (this goes for the 89 map too but there isn't much point since they should otherwise be the same).
